Activity Forums Apple Final Cut Pro Legacy P2 Playback in FCP
  • P2 Playback in FCP
    Posted by Ben Watson on March 12, 2009 at 8:10 pm
    Heya, me again. So i am editing my first project here in FCP with P2 footage, setup everything for 1080 60i, and all shot in same format. I transferred all my footage from P2 card via the transfer n log menu (plays back beautifully in there). When I go to edit, I can’t playback more than 2 secs and it starts jumping and stuttering(no filters or anything)
    I don’t think it is drive issues, as it is coming off a ESATA drive plenty fast to play in Trans menu and in P2 Manager…
    It’s really hard to edit this way. Any suggestions? (do I need to recompress it- YUCK!?)
    -Ben
    Ben Watson replied 17 years, 5 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    March 12, 2009 at 8:23 pm
    Are you sure the media in in your capture scratch which should be located on your Sata drive?
    Sounds like your media might be on your boot drive.
  • Ben Watson
    March 12, 2009 at 8:28 pm
    Yeah, its all on the Sata drive.
    Should I try moving it all to the primary drive? seems like that would be worse…
  • Shane Ross
    March 12, 2009 at 8:33 pm
    Does it stutter in the viewer? Do the sequence settings match the clip settings? Is the window size set to FIT TO FRAME? or larger?
    Shane
  • Jeremy Garchow
    March 12, 2009 at 8:36 pm
    No, you shouldn’t.
    make sure your footage and timeline settings match.
  • Ben Watson
    March 12, 2009 at 8:37 pm
    I think I may have found it…
    I had originally setup my scratch drive as a gigbit network drive, and I think all the footage is over there, not on my media drive…
    I noticed a huge spike in network activity on playback…
    I am transferring the data now…
  • Ben Watson
    March 12, 2009 at 9:46 pm
    BINGO, We have the slacker. I guess I need to leave the NAS to archival, eh?
    Ok, mental note: Use local transfers to get a guaranteed speed.
    – Thanks for your help guys…
    -Ben ( the FCP/Mac Newb )
