Activity Forums Panasonic Cameras P2 no longer recognized by pc
  • P2 no longer recognized by pc
    Posted by Gavin Impett on July 6, 2013 at 1:59 am
    Hi guys,
    camera is an HVX200
    2pc problems, I was able to get the p2 drivers working on one windows 7 64 bit machine, but now that one has stopped working. USB2 to Sony Vegas Pro 12 and recognized by windows explorer.
    Second machine win 7 64 bit, installed a pcmcia adapter, device not recognized by windows explorer or Sony Vegas Pro 12.
    Swapped cables, uninstalled, reinstalled drivers, any trick to getting this to work, or do I have to consider the possibility of a dead usb port.
    thanks,
    Gavin
    Gavin Impett replied 13 years, 1 month ago 1 Member · 1 Reply
  • Gavin Impett
    July 11, 2013 at 4:34 pm
    semi-solved driver issue, by reinstalling the drivers using the repair function, which persuaded the computer to recognize the pcmcia slot, so I can pull files that way. This did not get the USB2 connection to function again. That is still non-functional after previously working.
    Baby steps. But it does seem the pcmcia card will function if you double install the drivers – meaning install drivers – expect a fail, reinstall drivers, select repair, and away it goes. Worked with two pcmcia cards on two different machines.
    Good luck.
