Activity › Forums › Panasonic Cameras › p2 mxf files not recognized on FCP
Posted by Blitzr on March 8, 2007 at 4:48 pmHello, I have a PANASONIC AJ-HDX900 and i bought a external disk (Focus FS-100) to record my images.I taped it on DVDPRO HD and in quicktime and P2 formats.I have a Final Cut Pro editing system and in spite of seeing without any kind of problems the quicktime files i can
Barry Green replied 19 years, 6 months ago 6 Members · 7 Replies -
Jim Carswell
March 8, 2007 at 5:24 pmMy first questions is what version of Final Cut are you using? The most recent version, I think it’s 5.1.4, has P2 operability. Once your MXF files are on the hard drive- go to File> Import> Panasonic P2. Locate your MXF files and continue the import process. This will import the files as Quicktimes which are viewable and editable within Final Cut.
I hope this helps.
JimJim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com -
Jan Crittenden livingston
March 8, 2007 at 5:29 pmYou would need to do a P2 Organize on the Firestore prior to import. Did you do that? Also you didn’t record both MXF and QT at the same time right? So how did you do both? Or did you mean that you did some one way and some the other way?
jan
Jim Carswell
March 8, 2007 at 5:33 pmI didn’t catch that part Jan. Thanks.
JimJim Carswell
Savannah, GA
Shane Ross
March 8, 2007 at 5:38 pmI have a tutorial on this process:
And you need at least FCP 5.0.4.
Shane
Littlefrog Post
http://www.lfhd.net -
Freqsound
March 11, 2007 at 1:15 pmTo Shane:
What do you use to create the Mac onscreen footage like that in the tutorial mentioned above?To others:
I’m trying to do a drive recovery for some P2 footage (please be kind, I’m a computer and audio guy, but not a film guy). I’ve managed to get ALL of the MXF (both audio and video) files and folders as well as the BMP Clips. I could NOT retrieve the XML files. Is there Mac software that can recreate the missing XML wrapper files when all the other files are present and named correctly. Any help would be appreciated. Thanks.-Glenn
Shane Ross
March 11, 2007 at 4:55 pm[freqsound] “To Shane:
What do you use to create the Mac onscreen footage like that in the tutorial mentioned above?”Snapz Pro by Ambrosia Software.
Shane
Littlefrog Post
Barry Green
March 12, 2007 at 6:37 am[freqsound] “Is there Mac software that can recreate the missing XML wrapper files when all the other files are present and named correctly.”
P2 Log Pro from Imagine Software should be able to do exactly that.
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
