  • Shane Ross
    June 23, 2009 at 8:48 pm
    Put them in the trash, hold down the OPTION key, empty the trash.
    But these are your master tapes, are you sure you want to do this? Do you have them backed up somewhere? And by that I don’t mean you imported them into FCP as QTs, that is NOT a backup. You really should keep these. Get another hard drive. Internal 1TBs for around $99.
    Shane
  • Marc Brewer
    July 6, 2009 at 12:04 pm
    Thanks Shane…GEE I thought I tried this as it is an old apple OS command and it didn’t work but…..it did….
    Yes I have the original files backed up on 2 different HDs. this drive is my traveling edit drive so I needed the extra space….
    thanks again, since my brain had a sector error!
    Marc Brewer
    MarcusVision Media
