Activity Forums Panasonic Cameras P2 media will not import
  • P2 media will not import
    Posted by Grant Keiner on June 28, 2007 at 9:43 pm
    Hi all,
    I am working with P2 media and have a couple of reels that will not import. There is data there 7.2 gigs worth, but log and transfer won’t read them.
    I tried raylight it won’t read the mxf.
    I tried p2 log pro it won’t read them.
    I saw a post about editing the xml files, but that was from issues with the firestore. these files are not on a firestore. and when I opened xml the naming appeared to be the way the tutorial was telling me to make it.
    Does anyone know what else to try?
    I am at a loss.
    specs are FCP 6.0 P2 media transferred to a HDD via p2store. all the files but 2 from the shoot turned out fine.
    also tried importing into FCP 5.1.4 on another machine
    Scott Allman replied 19 years, 1 month ago 4 Members · 4 Replies
  • Shane Ross
    June 28, 2007 at 11:14 pm
    Copy the CONTENTS folder and LASTCLIP back to a P2 card, insert into the camera and use the REPAIR function…or even see if those will play in the camera. If they cannot be played or repaired, then they might be gone.
    This happens. Not often, but it happens.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • John Fishback
    June 29, 2007 at 1:37 am
    I use HD Log which is made by the same folks who make P2 Log Pro. HD Log has a P2 repair function. Check to see if P2 Log Pro has it, too.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • Scott Allman
    August 5, 2007 at 6:54 pm
    Shane,
    I just read this post. I thought you couldn’t copy files back to a P2 card.
    I am having import problems, but I can import from a P2 card just fine so I might like to try this.
    Scott
  • Scott Allman
    August 6, 2007 at 1:56 am
    I thought you couldn’t copy the CONTENTS folder and LASTCLIP back to a P2 card. I tried with no success. How do you do it?
    Scott
