Activity Forums Apple Final Cut Pro Legacy P2 Media Question
  • P2 Media Question
    Posted by Lou Borella on August 6, 2010 at 9:19 pm
    Will Final Cut recapture P2 media from a duplicate p@ data folder?
    Here is the workflow.
    After the shoot is finished the raw P2 data is backed up onto 2 separate G-Raid drives. One drive goes back to the studio and the other drive goes to the producers edit suite. The producer logs and captures the footage from his copy of the raw P2 data. He will do a pretty good rough cut.
    At this point can he send his working FCP project file to the studio and can the clips be recaptured from the duplicate raw P2 data folder? I’m hoping this will create a duplicate set of Quicktime movie files.
    Thanks in advance …
    Lou Borella
    Mike Schrengohst replied 16 years ago 4 Members · 3 Replies
  • Jeremy Garchow
    August 6, 2010 at 9:28 pm
    [Lou Borella] “At this point can he send his working FCP project file to the studio and can the clips be recaptured from the duplicate raw P2 data folder?”
    Yes.
  • Shane Ross
    August 6, 2010 at 9:35 pm
    As long as the folders have the exact same name, just hit BATCH CAPTURE and it will import the footage.
    Slick.
    Shane
  • Mike Schrengohst
    August 9, 2010 at 2:32 am
    Even better would be to Raylight all the files on each drive first…..
    Just keep the file structure the same.
    I do this all the time….
    No capturing needed.
    The only thing you won’t have is any rendered files.
