Activity Forums Panasonic Cameras P2 Media – from a data DVD to FCP
  • P2 Media – from a data DVD to FCP
    Posted by Eli Tishberg on March 23, 2007 at 7:32 pm
    I have some test P2 media that was sent to me on a data DVD and would like to import it into FCP.
    The P2 import doesn’t seem to work as it must be looking for the P2 card data structures.
    I have a bunch of folders on my desktop (VIDEO, AUDIO, CLIP) etc that are in the CONTENTS folder.
    Is there a way for me to import these files in FCP?
    Thanks…
    eli
    Frank Nolan replied 19 years, 5 months ago 3 Members · 5 Replies
  • Izoneguy
    March 23, 2007 at 7:36 pm
    The easiest thing to do is create a new folder on your harddrive:
    label it P2_DVD – then copy the CONTENTS folder and LASTCLIP.txt (if there is one)
    to this new folder.
    Then import>P2>P2_DVD
  • Frank Nolan
    March 23, 2007 at 10:45 pm
    What version of FCP do you have?
    If you are on 5.1.4 then all you need to do when you open the p2 import window is click on the buton in the top left corner of the window and navigate to the contents folder and click open. It will come up in the window and you can then open it and select the clips you want to import.
  • Eli Tishberg
    March 24, 2007 at 12:56 am
    Making a folder called P2_DVD worked perfectly.
  • Eli Tishberg
    March 24, 2007 at 12:57 am
    I am actually using 5.03 (I think) and the regular p2 import didn’t work.
    eli
  • Frank Nolan
    March 25, 2007 at 1:35 am
    Ahhh, you should upgrade to the latest version. It will open up a lot of P2 possibilities.
