Activity › Forums › Panasonic Cameras › P2 looking interlaced
  • P2 looking interlaced
    Posted by Julian Quiambao on November 9, 2008 at 5:55 am
    I shot with the HVX at 48fps and after transferring to FCP the footage looks interlaced. I thought it might be my Mac Book Pro monitor but if not, then what can I do to fix it. The camera is NTSC. I was told that there is a way to maximize the resolution of the footage in FCP but I also don’t know how to do that. Any input would be great.
    Julian Quiambao replied 17 years, 10 months ago 3 Members · 4 Replies
  • Noah Kadner
    November 9, 2008 at 6:32 pm
    It looks interlaced FCP on the canvas or output to an HD monitor? And send over a still if you would.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
  • Matthew Romanis
    November 10, 2008 at 12:32 am
    Check that your field dominance is set to none on both the file in the browser and the time line you are using. If set to “not set” on either it will default to the standard for your input settings. You should be able to control/right click on the item in the field dominance column in the browser to change these settings.
    Matthew.
  • Julian Quiambao
    November 10, 2008 at 4:24 am
    I am going to check it on a HD monitor today. If that still doesn’t work I will keep you posted. Thanks for the input and time.
  • Julian Quiambao
    November 10, 2008 at 4:26 am
    Thanks Matthew. I will check for that, check it out on a HD monitor, and then keep you posted. Thanks for the time and patience.
