Activity › Forums › Panasonic Cameras › P2 Issues – Digital Dropout (REDUX)
Adam Smith replied 14 years, 7 months ago 4 Members · 18 Replies
Shane Ross
January 26, 2012 at 11:49 pmPremiere Pro looks at the raw MXF files. If it sees that, than that is on the raw files.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Michael Morabe
January 26, 2012 at 11:58 pmThen that is the odd thing. I look at the original files off the card through either HVX200 or HPX500 and both are clean =/
FCP 7 Editor, Gaffer, Grip, Camera man…Swiss Army Knife!
Shane Ross
January 27, 2012 at 12:03 amSo, are you logging and transferring from the cards direct? or did you back up the files first? How did you connect the cards to a backup device? Maybe the backups are corrupt? Can you try to L&T directly from the cards?
Shane
Little Frog Post
Michael Morabe
January 27, 2012 at 12:12 amWe usually double capture directly from reader > FCP7. This isn’t the first time this has happened either. We just need a fool proof solution going into the webcasting captures.
Shane Ross
January 27, 2012 at 12:14 amMaybe the reader is dirty, or has issues. Try direct connection with the camera.
Shane
Little Frog Post
Steve Eisen
January 27, 2012 at 2:54 am[Michael Morabe] ” We just need a fool proof solution going into the webcasting captures.”
Very odd behavior. I use Shotput Pro to back up my P2 cards to 2 drives via the PDC35 card reader. Sometimes the PCD2. I use Log and Transfer and have no problems.
Shotput Pro will verify the offload.
I would check with a different card reader to start.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group -
Michael Morabe
January 27, 2012 at 4:24 pmWe just find it hard to believe the PCD20 is already crapped out. I’ll have to bring up getting another reader to test out. I still don’t like that even through Firewire 400 it still has a possibility to cause issues.
Adam Smith
February 11, 2012 at 9:21 am[Michael Morabe] “We just find it hard to believe the PCD20 is already crapped out. I’ll have to bring up getting another reader to test out. I still don’t like that even through Firewire 400 it still has a possibility to cause issues.”
If you suspect the reader, you can always connect the 200 or 500 via Firewire/USB and try a direct offload to see if anything changes. I always write-protect the cards before mounting too.
Video Photographer / Avid & Final Cut Editor
