Activity › Forums › Adobe Premiere Pro › P2 Issues
  • P2 Issues
    Posted by Peter Tours on December 20, 2012 at 8:34 pm
    I am editing from native P2 files from an HPX500. See the picture – notice the original sequence settings are corrrect for P2 1080 601/30p; then notice Pr wants to change them; then notice what happens when you allow it to…CUSTOM. If I were to decline Pr’s request to allow it to change sequence settings, it doesn’t and accepts and plays the clip….does this make sense to anyone? My project is the former, not the latter scenario. Perhaps I chose poorly?
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to not too much longer
    Adobe Creative Cloud
    Jeff Pulera replied 13 years, 9 months ago 3 Members · 5 Replies
  • Angelo Lorenzo
    December 21, 2012 at 12:59 am
    “Editing modes” are just camera-specific presets for the timeline size and preview codecs. They are malleable and any deviation will become a “custom” edit mode.
    If you look closely, the only thing that has changed is that Premiere sensed that your footage was non-drop-frame, while the strict P2 preset assumes drop-frame timecode.
    The preview codec and other timeline specifications remain identical so far as I can tell.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Peter Tours
    December 21, 2012 at 3:05 am
    Angelo – the good news is your eagle eye found what my dyslexic eye couldn’t – the subtle difference, which I will take up with my crew. But drat, I guess this does not explain why playback is lousy and Pr crashes a lot. Back to te drawing board, Thanks!
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
  • Jeff Pulera
    December 21, 2012 at 3:13 pm
    Hi Peter,
    What I’m seeing is that the original sequence preset shows UPPER FIELDS, where the custom preset shows PROGRESSIVE
  • Peter Tours
    December 21, 2012 at 3:21 pm
    Thanks, that’s why I posted it, so others can see what I don’t. So we now know it changes NDF to DF and Interlaced to Progressive. Now we need an explanation why? Hello, Abode??
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
  • Jeff Pulera
    December 21, 2012 at 4:05 pm
    Hi Peter,
    What struck me from the start was the description of the P2 Sequence that said it was for “1080i – 1080p”. I’ve never seen an Adobe preset COMBINE the two, because they are DIFFERENT and usually each have their own preset. The above preset shows “Upper Field”, so that is obviously then NOT progressive. Therefore when you dropped progressive footage into that sequence, Premiere wanted to change the setting to match the footage, which it did by changing the fields to progressive.
    So I feel that the custom preset is correct and should work fine for you then.
    Jeff Pulera
    Safe Harbor Computers
