Activity Forums Adobe After Effects P2 Interpret Footage
  • P2 Interpret Footage
    Posted by Whitlock Dunbar on February 15, 2008 at 3:14 pm
    Ok what am I doing wrong…
    I have the 8.0.2 update, and I’ve imported my .mxr files into AE. I drag the clip onto the New Comp icon, and the clip in the comp has an incorrect aspect ratio.
    I highlight the clip in the Project Window and its properties are:
    960×720 (1.33)
    Millions of Colors
    dvn7
    Interpret Footage reveals:
    HDV 1080/DVCPRO HD 720 (1.33)
    And the Composition Settings are:
    Preset: DVCPRO HD 720 29.97
    Width: 960
    Height: 720
    Pixel Aspect Ratio: HDV 1080/DVCPRO HD 720 (1.33)
    The clip’s icon in the project window looks correct by the way.
    I have been experimenting with various comp and clip PAR options and the only solution seem to be to adjust the scale (which I’d rather not do).
    I hope I’m missing something very simple…
    Brian Kim replied 18 years, 7 months ago 2 Members · 3 Replies
  • Whitlock Dunbar
    February 15, 2008 at 3:30 pm
    I figured it out…
    The source footage was shot vertically (rotated 90 degrees); once I rotated it everything was cool. Seems odd but whatever…
  • Whitlock Dunbar
    February 15, 2008 at 6:07 pm
    You’re right on all counts:
    1) I was not aware of the PAR switch
    2) It did indeed look “funny” after rotating 90 degrees; I jumped the gun on my follow-up post.
  • Brian Kim
    February 15, 2008 at 9:45 pm
    “Unfortunately, it won’t remain cool after it’s been rendered. It will look too tall & skinny, or squeezed horizontally if you want to refer to it that way, if you compare it to the original footage.”
    Hi Dave,
    I just realized in one week I’m about to find myself in a similar situation where I’ll be taking DVCProHD 1080i footage shot vertically (rotated 90), keying out elements, and bringing those elements into a composition where our background plates were shot standard (horizontally oriented).
    I know my keyed elements will be tall and skinny, and I had been anticipating that scaling them down vertically is a better option than scaling them wider in order to achieve the correct proportions, however since I saw your feedback in this post I was wondering if you had any other suggestions or advice on how to retain the best resolution/avoid pitfalls.
    Will mixing these orientations bug AE CS3 out at all?
