Activity Forums Panasonic Cameras P2 ingest into FCP trouble (Folder copied but clips not appearing)
  • P2 ingest into FCP trouble (Folder copied but clips not appearing)
    Posted by Alexander Lucas on November 10, 2006 at 12:04 am
    I have been trying to find a post with a similar problem but I have been working on an HD feature. The first 14 P2 cards copied fine and was able to ingest all perfectly. Then I got a spate of 8 cards of 15 that did not load. What would happen is that I would add the copy of the card to the Import P2 menu, and it would show the folder, but not show any clips underneath it. Furthermore, I can see inside of the folder (in Finder) that the thumbnails are all there and are the same as the clips that should be there.
    Is there a way to fix this (on the Camera fix clip function) or was this a problem from the original copying? Can I salvage anything from the MXF files or anything?
    I am using the latest version of FCP (5.1.2).
    Alex
    Alexander Lucas replied 19 years, 10 months ago 2 Members · 4 Replies
  • Izoneguy
    November 10, 2006 at 10:33 pm
    Try clicking the little arrow beside the card icon.
  • Alexander Lucas
    November 10, 2006 at 10:51 pm
    Well that is the problem…for these cards it just appears as a folder with no arrow. The ones that worked properly had arrows which I could swirl down and see the clips.
    All it appears as is the folder with no clips in it.
    As I said in the original post, most of the cards have worked and I have seen how the clips import, but these come up differently in the P2 import window, though it does read that they are P2 folders.
    Alex
  • Izoneguy
    November 12, 2006 at 2:49 am
    Did you check the CONTENTS folder to make sure all the folders
    and files are intact?
  • Alexander Lucas
    November 12, 2006 at 9:22 pm
    Yes. Everything appears normal except that it does not show up in the P2 import window correctly. I can even see the thumbnails of the clips in one of the folders.
