Activity Forums Panasonic Cameras P2 IMPORT PROBLEM SOLVED—-MAC USERS READ ON
  • P2 IMPORT PROBLEM SOLVED—-MAC USERS READ ON
    Posted by Sean Fine on June 28, 2006 at 5:13 pm
    FYI to all HVX-200 users that are importing through MAC. I recently used a G4 Power Book to copy P2 footage to a Raid 1TB drive in the field. When I returned home some of my clips would not import. After a few days of pulling my hair out I solved the problem. The problem was in how I named my folders in the G-raid that contained the P2 information. I used the
    Dean Sensui replied 20 years, 2 months ago 5 Members · 5 Replies
  • Noah Kadner
    June 28, 2006 at 7:12 pm
    That kind of goes in general for computers and also FCP. Anything other than _ or – is not a great idea to use. Stick with numbers and the alphabet.
  • Dean Sensui
    June 28, 2006 at 7:46 pm
    Thanks for the heads-up on this.
    As a general rule, I avoid any special characters in file names and folder names. It’s a holdover from the old days where you were limited to characters and numbers. It’s probably still a good practice as there’s a chance an odd character could trip up an operating system as you’ve discovered.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Mitch Ives
    July 3, 2006 at 4:31 pm
    [Fine Productions] “I used the
  • Eric Bliss
    July 3, 2006 at 7:46 pm
    Just for reference, here’s a list of characters to avoid in your filenames to protect yourself from problems with UNIX…
    Yes, I know that’s virtually everything that’s not a number or a letter. Hence, the rule of only using letters, numbers, and the underscore.
    Eric Bliss
    systems design and integration
    CreativeCow.Net
    int main(void) {
    printf(“Hello World!\n”);
  • Dean Sensui
    July 3, 2006 at 7:58 pm
    [Eric Bliss]
    Looks like a string of nasty words from a comic strip!
