Activity Forums Apple Final Cut Pro Legacy P2 Import into FCP missing files!
  • P2 Import into FCP missing files!
    Posted by Dan Bennett on March 20, 2010 at 12:56 am
    So I have this project working in Standard Def off of HVX P2 cards.
    The cards have been trasnfered to a hard drive and I’m properly using the LOG AND TRANSFER in FCP.
    However, I’ve noticed that while the files loud in the Log and Transfer window, when I look in the Video Folder under Contents, there are more MXF files there, than what the Log and Transfer window is showing me.
    For example.
    I add custom path, choose CAM 1 Card 1> and it loads 5 clips into the Log and Transfer window.
    They import fine. But, when I double check the CAM 1 Card 1>Contents>Video folder, i see 7 MXF files.
    can anyone tell me whats going on here?
    Now, I’m working with a LOT of footage, 3 days worth on 3 cameras, each with half a dozen cards used.
    Shane Ross replied 16 years, 6 months ago 2 Members · 3 Replies
  • Shane Ross
    March 20, 2010 at 1:24 am
    P2 cards are formatted FAT32, so they have a 4GB limit. So when you record LONG takes, the cards break up the takes into multiple parts. So while you might have 4 clips, FCP sees them as one continuous clip and joins them together. You might see in the L&T interface that some of the clips say SPANNED. Those are clips that are grouped. Some might span from one card to the next.
    This is normal.
    Shane
  • Dan Bennett
    March 20, 2010 at 1:34 am
    Thankyou so much! That makes so much sense!
    You just saved me a crap load of stress!
  • Shane Ross
    March 20, 2010 at 1:57 am
    I was in your same shoes when I first got footage from the camera. But the workflow was VERY rough back then too. I was kinda stressed about that as well.
    Good Luck
    Shane
