Activity Forums Apple Final Cut Pro Legacy P2 import error
  • P2 import error
    Posted by Michael Black fcp on June 20, 2006 at 7:44 pm
    So I received three hard drives with P2 card footage on them. Upon mounting the drive and attempting to import the mxf files, I get so far as to be able to see the thumbnails and timecode, etc., but when I try to import one or all of the files, I get an error message saying that it can’t import them. Is there something I’m not doing right? Any help would be greatly appreciated.
    Michaelblack
    Michael Black fcp replied 20 years, 3 months ago 3 Members · 3 Replies
  • Shane Ross
    June 20, 2006 at 8:02 pm
    Watch my P2 import tutorial and see if there is any step you are missing, then get back to us:
    P2 Workflow Tutorial
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Daryl K davis
    June 20, 2006 at 8:19 pm
    Are the drives with the clips full because when you import the media clips they do re-render as quicktimes, thus you need sufficient drive space.
  • Michael Black fcp
    June 22, 2006 at 3:38 am
    Shane,
    Your piece did the trick. I was working off of 5.0.3 and had to update it to 5.0.4. No problems after that. Thanks a ton.
    Michaelblack
