Activity Forums Panasonic Cameras P2 Import Error FCP 5.0
  • P2 Import Error FCP 5.0
    Posted by Joel Knoop on April 11, 2007 at 11:54 pm
    Hi All.
    Had my first problem importing to FCP via P2 slot on my powerbook G4 today.
    I am running FCP 5.0. OS 10.3.9.
    Got an error message saying: “One or more P2 clips failed to import; probable incomplete of corrupt files.”
    I have tried repairing clips in the camera, tried drag and drop to the desktop method.
    (I usually import via FCP: file>import>P2.)
    I can watch the files on the camera, and I see thumbnails in the import window… but no import.
    Any ideas?
    Also can I “log and capture” from the 1394?
    Thanks.
    Barry Green replied 19 years, 5 months ago 4 Members · 4 Replies
  • Shane Ross
    April 12, 2007 at 5:25 am
    FCP 5.0…not 5.0.4? You need FCP 5.0.4 and QT version 7.1.3 MINIMUM in order to import P2 footage.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • David S.
    April 12, 2007 at 3:18 pm
    If you are referring to log and capture via firewire from a p2 card, no
  • Joel Knoop
    April 12, 2007 at 3:45 pm
    Interesting. Import worked for me for about 3-4 months no problem.
    Then all the sudden stopped working.
    Any idea why that would be?
    Thanks.
  • Barry Green
    April 12, 2007 at 5:55 pm
    5.0 can import standard-def, but you need 5.0.4 to import high-def. So were you doing standard-def before and just now switched to high-def?
    Also, FCP had bugs that prevented it from successfully importing all clips. Especially susceptible were clips that were repaired in-camera; if you’re using 5.1.1 or earlier, it fails to successfully import those clips (even though every other program or app can). Those bugs seem to be resolved in 5.1.4. Best thing for you to do is upgrade.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
