Activity Forums Apple Final Cut Pro Legacy P2 Import error
  • P2 Import error
    Posted by Steven Ware on August 25, 2007 at 9:16 pm
    When i go to import my mxf files in to fcp not all of the shots appear in the log and transfer window. When I look at the contents folder on the drive it shows (for example) 5 clips but when i open it in the log and transfer there is only 4. it does this with every card I try. Always one or two dont come through to fcp. The rest are fine.
    i am on 6.0.1 the files were backed up using a pc laptop and the hard drives the cards were saved on is formatted NTFS. Each card is saved into its own folder with the lastclip files and nothing is changed or renamed.
    Im lost. Help
    catawampus is online now Report Post Edit/Delete Message
    Steven Ware replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
