Activity Forums Panasonic Cameras P2 HD and Avid Adrenaline
  • P2 HD and Avid Adrenaline
    Posted by Paul Brubacher on December 4, 2007 at 4:52 am
    We had a HPX3000 for a demo the other day. I love the camera, but working with P2 HD and Avid Adrenaline was pretty slow. Is there a way to work in full rez DVCPROHD without having to do a DNX transcode? SD worked great, so will we just have to wait for HD to get faster? We have 5 Avid Adrenaline’s 2.7 with a Unity using Interplay. Does anybody have some work arounds or settings to check?
    Paul
    Barry Green replied 18 years, 9 months ago 2 Members · 5 Replies
  • Barry Green
    December 4, 2007 at 6:38 pm
    Shouldn’t have been slow… a Mac Pro can handle multiple streams of HD in realtime even off the internal hard disk. Don’t know why the Avid would have been slow… ?
  • Paul Brubacher
    December 4, 2007 at 9:44 pm
    Hi Barry, It is the importing that takes so long. If you do a transcode to the Avid DNA when you import it took about 3-4x. If we ran using the native DVCProHD we didn’t have full rez output, then had to transcode to print to tape.
  • Barry Green
    December 5, 2007 at 6:14 pm
    What kind of tape are you printing to? Why wouldn’t you leave it in the native format?
  • Paul Brubacher
    December 5, 2007 at 10:12 pm
    We print back to a DCVPROHD deck or to a Beta SX. Are you saying that I should be able to edit in draft/half mode then print to tape in Full Rez. If so what should my project setting be at? When we tried to print to tape it would want to do a transcode. By the way our AVID’s have been set up so you only have the option of editing in DNA145, could that be a problem.
  • Barry Green
    December 6, 2007 at 12:39 am
    If you’re printing back to a DVCPRO-HD deck, why would you want to transcode away from the native format at all? Import the MXFs as DVCPRO-HD (instantly), edit multiple streams in realtime, and export via firewire the unmodified data.
    The DNA145 issue may be the problem. I know in the “lesser” Avids, like XPress Pro, you can plug in a card, drag files right to the bin, edit immediately (no transcoding, no ingesting, no anything) and export via firewire (or HD-SDI if you want that option) back to a deck…
