Activity Forums Panasonic Cameras P2 Frame Grabs for print
  • P2 Frame Grabs for print
    Posted by Fargoross on September 19, 2006 at 1:58 pm
    Though I do understand that these images are not great nor are they intended for print, our clients want the highest quality possible
    frame grabs from our P2 footage (720pn60) for a publication.
    Exporting an image from FCP gives me that squished 960×760 frame, and exporting from the quicktime movie looks pretty bad, the anti aliasing and compression are quite evident… and i am deinterlacing..
    Does anyone know of a good workflow for getting the best quality frame grabs from P2 footage?
    I’ve tried the export from FCP, and the export from QuickTime, and I have selected high quality playback, and done ‘none’ for compression on the export.
    Anyone else have any ideas?
    Ross Hendrickson
    Gunleik Groven replied 20 years ago 6 Members · 5 Replies
  • Izoneguy
    September 19, 2006 at 3:40 pm
    If your have Photoshop just re-size the images…
    You can also adjust gamma & brightness…
    Thats what we do and the results look great!
  • Barry Green
    September 19, 2006 at 4:07 pm
    You should never, under any circumstances, de-interlace progressive footage; the only thing that accomplishes is to cut your resolution in half.
    I’m no FCP expert but I’ve done this before; eExport a single frame from FCP and then resize and correct the aspect ratio in PhotoShop.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Uli Plank
    September 20, 2006 at 6:16 am
    For the highest possible quality, do the uprezzing with Photo Zoom Pro.
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
  • David S.
    September 20, 2006 at 4:09 pm
    PhotoZoom Pro is a great program for this. Available for Mac or PC.
  • Gunleik Groven
    September 20, 2006 at 10:03 pm
    One nice way of grabbing frames, is to open the file in Quicktime, select the desired frame and hit copy and paste directly into a new photoshop document.
    You can have a look at the result here:
    https://www.vulture.no/testvid
    Cheers!
    Gunleik
