Activity › Forums › Panasonic Cameras › P2 Formatter
  • P2 Formatter
    Posted by Paul Turlick on December 8, 2009 at 6:31 pm
    Hi-
    Downloaded P2 Formatter (for Mac) from the Panasonic site. Installed the driver for the AJ-PCD20 and then downloaded P2 Formatter. When I insert a P2 card it shows up on the desktop but is not recognized by the formatter software. I’ve tried some re-installing etc but no luck.
    The only thing I could think of (which is probably not right) is if there’s a problem because the card is a Fuji E series. BTW- it’s a 64 GB card.
    Thanks-
    Paul
    Paul Turlick replied 16 years, 9 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    December 8, 2009 at 8:03 pm
    [Paul Turlick] ”
    The only thing I could think of (which is probably not right) is if there’s a problem because the card is a Fuji E series. BTW- it’s a 64 GB card.”
    Yes, that’s right. You also have to update the firmware on the PCD20, PC only though. I use Parallels on a Mac to do the updating, but you will need to buy it and a copy of Windows.
    Jeremy
  • Arthur Aldrich
    December 9, 2009 at 12:38 am
    Keep in mind that the P2 Formatter only works on Firewire.
    I doubt that it is a firmware issue, otherwise the card would not mount on the desktop. I suspect that you are using USB perhaps to connect?
    Art Aldrich
    OTEK TV
    Leader, NJFCPUG
    http://www.njfcpug.org
    http://www.otek.tv
  • Jeremy Garchow
    December 9, 2009 at 3:35 pm
    [Arthur Aldrich] “I doubt that it is a firmware issue,”
    I’m pretty sure it is. Go to this page:
    https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/update.htm#p2_mac
    Check out the version that needs to be in the PCD20 in order for Eseries cards to work.
    Then read this.
    https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/pcd20/pcd20.htm
    I had to update my PCD20 with Parallels and Windows before I could get an E series P2 cards to work properly, even though they mounted ok.
    Jeremy
  • Paul Turlick
    December 15, 2009 at 6:10 pm
    FYI- it seemed to be a USB v. FW as someone said. I tried with FW and it worked fine.
