Activity › Forums › Apple Final Cut Pro Legacy › P2 flagging incorrect frame rate
  • P2 flagging incorrect frame rate
    Posted by Lawrence Klein on December 3, 2008 at 9:28 pm
    I’m having the same problem as this post and i have updated to 6.0.5 Was there ever a solution to this problem?
    I have tried the reversed pulldown in the log and transfer window, as well as in the tools menu and both are incorrect creating interlaced footage
    P2 flagging incorrect frame rate?
    by Rich Rubasch on Aug 18, 2008 at 11:37:17 am
    We got clips from an HDX 500 and they come in flagged as 1080p30, however the camera guys swears they were shot 1080i 24p. They have the three progressive frames followed by two interlaced frames, just like the old 24 fps film transferred to Beta used to look like, but this stuff is very juddery.
    What gives? How can the clips be flagged incorrectly?
    Or are they?
    Lawrence Klein replied 17 years, 9 months ago 2 Members · 2 Replies
  • Andreas Kiel
    December 3, 2008 at 11:39 pm
    If you still got a copy of the P2 cards you can have a look in into the P2 clip XMLs. There you can see how they where recorded.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Lawrence Klein
    December 4, 2008 at 6:06 pm
    Thanks, good tip..
    this solved the mystery of what was actually shot.
