Activity Forums Apple Final Cut Pro Legacy P2 files play in Transfer window but won’t import
  • P2 files play in Transfer window but won’t import
    Posted by Steve Hobbs on January 19, 2011 at 11:21 am
    Having a problem with P2 files not importing. There are several P2s from same cards that will import but 3 files refuse to cooperate. They will play in Transfer window but will not import. Using FCP 7.0.3, tried it on 3 FCP systems. P2s reside on a G-RAID 4TB and a portion on the files can not be copied to another drive (getting error code 36: “The finder cannot complete the operation because some of the data in could not be read or written”). Any ideas on how to get these files imported/repaired? Thanks.
    Susan Dempster replied 14 years, 11 months ago 4 Members · 5 Replies
  • Chris Tompkins
    January 19, 2011 at 12:46 pm
    Did you use P2CMS to original transfer the content off the card onto a hard drive? With verify?
    Chris Tompkins
    Video Atlanta LLC
  • Jeremy Garchow
    January 19, 2011 at 2:14 pm
    Perhaps there’s a permissions error on the files.
    Try opening in p2CMS and see if they work there.
  • Steve Hobbs
    January 19, 2011 at 3:10 pm
    Tried it in P2CMS and the files in question do not play. If fact they crashed P2CMS. A corrupt file I guess.
    But since it shows in Transfer window is it possible to fix?
  • Jeremy Garchow
    January 19, 2011 at 3:12 pm
    Do you have the original card structure and a camera? I’d try loading the material back on to a p2 card and repairing them in camera.
    Jeremy
  • Susan Dempster
    October 11, 2011 at 3:02 pm
    I am having the same problem –
    Steve, were you able to resolve this (and how0?
    Jeremy, can you explain how to repair in camera?
    Thank so much!
