Activity › Forums › Adobe Premiere Pro › P2 files duplicating when imported in Premier Pro CS5
  • P2 files duplicating when imported in Premier Pro CS5
    Posted by Scott Montgomery on June 29, 2012 at 10:26 pm
    Hey, I’m having a problem import all of my P2 files into a project in Premiere Pro CS5. I have 10 files I want to use but when I import them into the project 3 of the files are imported as duplicates of the files that comes before them in the series. All of these files were shot at the same time with the same camera. I have tried creating a new project and importing them and it happens again.
    Any advice?
    Mike Cohen replied 13 years, 11 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    July 1, 2012 at 7:29 pm
    Use the media browser window in Premiere to import any file format that uses spanned clips.
    I assume the issue arises because you drag your files straight into the project bin?
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
  • Scott Montgomery
    July 1, 2012 at 8:33 pm
    I’m using the media browser. When I open up the folder they are in the 3 files that wont import do not appear. If I open the folder outside of premiere they are there…
  • Mike Cohen
    October 8, 2012 at 9:10 pm
    We just noticed this as well – in the case of longer record runs, Premiere sees clips that are part of the same record run as one clip.
    Mike Cohen
