Activity Forums Panasonic Cameras P2 FCP render render render!!!
  • P2 FCP render render render!!!
    Posted by Michelle De long on October 16, 2006 at 9:08 pm
    We shot a project on the P2 in DVCPRO25 24PA.
    We are trying to figure out how to set up the sequence setting in FCP so that we don’t have to render everytime we drop a clip into the timeline.
    Any thoughts?
    Izoneguy replied 19 years, 11 months ago 3 Members · 5 Replies
  • Izoneguy
    October 16, 2006 at 9:48 pm
    With 24PA you most remove the pulldown before editing…
    Depending on your FCP version?
    With FCP 5.1.2 the remove advanced pulldown works in the
    P2 import. You should then be able to use the DV NTSC 23.98 easy set-up….
    If you any version below 5.1.2 you must use Cinema Tools to
    remove the advanced pulldown before editing.
  • Noah Kadner
    October 17, 2006 at 2:51 pm
    Cinema Tools doesn’t come into the equation ever for 24pA. It is automatically handled by FCP from version 4.0 up.
    Noah
  • Izoneguy
    October 17, 2006 at 7:07 pm
    Noah, you can do it either way.
    I just did a test with P2 shooting DV at 24pA
    The remove advanced pulldown with FCP 5.1.2 actually
    works when you capture from P2 now…..
    If you forget to check the box yes you can select the clip
    and go Tools > Remove Advanced Pulldown.
    Versions below 5.1.2 the option to Remove Advanced Pulldown during
    P2 capture does not work.
    You then have to use Tools > Remove Advanced Pulldown.
    Using Cinema Tools is an option to batch process a bunch
    of clips so you don’t have to sit there and do it
    one at a time.
  • Noah Kadner
    October 17, 2006 at 11:30 pm
    Yes of course it can be used- I was taking your meaning to be it *must* be used.
    Noah
  • Izoneguy
    October 17, 2006 at 11:32 pm
    I understand! I hope the original posted was able
    to figure it out.
