P2 – FCP Log(jam) and Transfer
Like the many other P2 to FCP posts, I am having Log and Transfer issues with P2 footage.
Have a new Macbookpro with Snow Leopard
I unwittingly migrated FCP over from my old macbookpro and it worked fine until i tried to use compressor and it wouldn’t work so i then re installed FCP.
So now when I attempt log and transfer from either external drive or direct from camera (tried many different clips from my archives that i have previously used no probs.)
You can see the clips but they wont ingest(red excl. point ‘no data’ etc) UNLESS… they have no audio, or are at a higher frame rate (ie:no audio)
I unchecked the audio in import settings in log and transfer to test this and the clip will then ingest no problem.
I have re-installed FCP
I have upgraded FX Factory (and then uninstalled it)
I feel like I’m getting close…I have unchecked the ‘remove advanced pull down’ preference.
Peter
