Activity Forums Panasonic Cameras P2 FCP – HELP!!! THANKS!
  • P2 FCP – HELP!!! THANKS!
    Posted by Openfilms on September 7, 2007 at 6:21 pm
    Help… Thanks…
    I can an error message with FCP “one or more clips failed to import; probable incomplete or currupt clips.”
    Using:
    Apple Powerbook G4
    Mac OS X version 10.4.7
    Processor 1GHz PowerPC G4
    1 MB L3 cache
    Memory 1 GB SDRAM
    FCP 5.0.4
    QT 7.1.3
    Any advice would be grand!
    Thanks, Mark
    Jonas Cox replied 19 years ago 3 Members · 2 Replies
  • Noah Kadner
    September 7, 2007 at 8:15 pm
    Upgrade your FCP to the latest version via Software update.
    Noah
  • Jonas Cox
    September 9, 2007 at 5:39 am
    Had the same problem. Previous poster is right; you need to upgrade. If you can’t afford the upgrade (I think you can only go to 6 from 5.0.x, and that $$s), find someone with FCP 6 (you might be able to do it with 5.1.x, but not sure). Use their system to do the import; the clips will retain any special formatting (like pulldown of regular 24p) that you imported them with, and playback fine in 5.0.x.
