Activity Forums Apple Final Cut Pro Legacy P2 Downconversion
  • P2 Downconversion
    Posted by Joe Editor on September 12, 2006 at 2:52 am
    I imported some footage from a dvx-200 P2 camera into FCP…my sequence setting are HD(960X720)(16:9) and compressor is DVCPRO HD 720p60…can anyone please tell me what is the best way to down convert and preserve the 16:9 aspect ratio…what should my settings be…
    please advise as soon as it is convinient.
    Joe
    Alfredo Barros replied 19 years, 11 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    September 12, 2006 at 3:55 am
    Use a Kona card and do it through hardware in real time…or…if you don’t have a local Kona shop that’s open this evening, I have a question for you. Do you want to downconvert a finished sequence or do you want to downconvert all of your clips to edit in an SD timeline?
    Jeremy
  • Alfredo Barros
    September 17, 2006 at 4:27 am
    OK, I will get a “hitchhiking” on this topic. I am curious about the best workflow to edit OFFLINE with the P2 media files. Is there a way to down convert from HD to DV mantaining the same TC to reconect the project
  • Alfredo Barros
    September 17, 2006 at 4:33 am
    Sorry, I change the word AFTER for BEFORE in that frase:
    “I always worked (until now) in an ONLINE=>OFFLINE=>ONLINE workflow, down converting my digibeta media files to DV in an ONLINE finish house and than recapturing again (AFTER) in DIGIBETA only the media used in my project.”
    Thanks.
    Alfredo Barros
    Alfredo Barros
    Final Cut Editor
    Porto Alegre-Brazil
