P2 directory structure / missing contents folder / READ ERR!
I installed the driver for the AJ-PCD20 and two hours later got the P2 cards to mount on my desktop. (I’m running Snow Leopard and had a ridiculous time finding the driver for that, almost reinstalling my original OS to make this work.)
Finally the cards mounted and all that is on them is the .txt file. They each show almost 16 gig avail (16 gig cards.) One card’s info shows date last modified 11/29 and the other shows last night (when I was working with them) as the last modified date. When the cards were put back into the camera to check for clips it said “READ ERR!” in red.
I ran Treasured on my Mac and it found a lot of clips on one of the cards. The other card shows 51 files but it needed ‘human review’ to see if the files were recoverable. This may be because you are only allowed one ‘review’ before having to buy the program (?) but I need to make sure it works like I need it to before spending the money.
Both cards’ errors show “the unit ran out of battery while recording”. I am not the camera operator, I am here strictly to edit.
Is there are way to rebuild the directory structure (FCP gave me THAT error on both cards) and also get the Contents folder to show up?
I am at the point my eyeballs want to fall out of my head.
Thank you, in advance, for any help.
Sandy
