Activity › Forums › Panasonic Cameras › P2 device driver for PowerBook
  • P2 device driver for PowerBook
    Posted by Oliver Peters on January 29, 2006 at 10:15 pm
    As I remember from the info in the last Apple updates that enabled P2 workflow, there was a required device driver to properly mount the P2 cards. This was a Panasonic download. Anyone aware of this and if so, where do you find it? Thanks.
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
    Oliver Peters replied 20 years, 8 months ago 2 Members · 3 Replies
  • David S.
    January 29, 2006 at 10:35 pm
    I believe FCP 5.04 supported importing the P2 card data.
    No driver needed to actually mount and copy the p2 card to the PB with a cardbus slot
    David S.
  • Oliver Peters
    January 30, 2006 at 1:04 am
    I’m not so sure. This is from the Apple document “Late-Breaking News about Final Cut Pro 5″ which was online as part of the 5.04 update documentation:
    ” Inserting the P2 Card into the PC Card Slot of a PowerBook
    The fastest way to get media from a P2 card into Final Cut Pro is through the PC Card
    (PCMCIA) slot of a PowerBook. This method requires driver software from Panasonic.
    To transfer media from a P2 card using the PC Card slot of a PowerBook:
    1 . Make sure the Panasonic driver software is installed on the PowerBook.
    For more information, go to https://www.panasonic.com/broadcast.
    2 . Insert the P2 card containing the media you want to import into the PowerBook PC
    Card slot.
    The memory card appears on the desktop as a mounted disk named NO NAME. ”
    The URL link in the PDF is a generic Panasonic Broadcast link with no specific related info on that page. A search of the Panasonic site hasn’t yielded anything yet.
    Sincerely,
    Oliver
    Oliver Peters
    Orlando, FL
  • Oliver Peters
    January 30, 2006 at 1:17 am
    Just got this link from a friend:
    https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft_e.htm
    Thanks.
    – Oliver
    Oliver Peters
    Orlando, FL
