Activity Forums Panasonic Cameras P2 Copy to Hard Drive via Firewire
  • P2 Copy to Hard Drive via Firewire
    Posted by Mike Turecamo on January 14, 2011 at 1:53 pm
    Good morning, I’m trying to copy P2 cards directly to a G-Tech hard drive. I follow the steps correctly. When I get to the in camera menu that should allow me to copy the only option I get is set up, the other options are shaded and can’t be accessed. Anybody have a clue?
    Mike
    Mike Ironriver replied 15 years, 7 months ago 3 Members · 4 Replies
  • Shane Ross
    January 14, 2011 at 4:35 pm
    If I recall right, The only way to copy directly from a camera to a hard drive is via USB. It doesn’t work via Firewire.
    Shane
  • Mike Turecamo
    January 15, 2011 at 5:11 pm
    Hi Shane Mike here…there are instructions to transfer directly to hard drive…its also on the menu
    Mike
  • Mike Ironriver
    February 18, 2011 at 5:06 am
    Just to make sure: you need to choose the firewire Host option in the menu. (Last menu point – Other Functions.)
  • Mike Ironriver
    February 18, 2011 at 5:11 am
    It works fine on mine with firewire. Just to make sure: you need to choose the firewire Host option in the menu. (Last menu point – Other Functions.)
    If you are using an G-tech mini drive (2.5 form factor) you need to provide power separately. Firewire doesn’t provide power for the drive.
