Activity Forums Panasonic Cameras P2 clips in Time Coder order
  • P2 clips in Time Coder order
    Posted by Scott Sniffen on June 25, 2009 at 9:07 pm
    How or can the P2CMS software preview the clips in time code order? I have the time code displayed on each clip but they are in random order.
    Scott Sniffen
    John Fishback replied 17 years, 2 months ago 2 Members · 1 Reply
  • John Fishback
    June 26, 2009 at 3:22 pm
    I don’t use this software, but it may act similarly to whai I use. If you have a column of timecode numbers, try clicking on the column name, for instance, “start timecode.” Usually on a Mac that will cause the column data to be sorted numerically, alphabetically, etc. Click again and the sort will reverse.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
