Activity › Forums › Panasonic Cameras › P2 clip into FCP
  • P2 clip into FCP
    Posted by Yiannis Valkan on June 11, 2010 at 12:11 pm
    Hi all,
    I know that FCP CAN import P2 files from log and transfer option,
    but i would like to know if there is somewhere an otion to rename the clips. (Very annoying the naming P2 does).
    If not (which i think there is not) i would like to know if there is another utility that can do that thing for me.
    Free is better…
    Thanks in advance,
    Yiannis
    John Fishback
    replied 16 years, 3 months ago
    3 Members · 2 Replies
  • Jeremy Garchow
    June 11, 2010 at 2:48 pm
    P2CMS can rename claips, but it’s not better than log and transfer, but it is free.
    The one that I use which is not free is P2 Flow from MXF4mac. Worth every cent. Very fast and easy to edit metadata.
  • John Fishback
    June 11, 2010 at 6:36 pm
    If you just want to rename clips, you can do that in the L&T Clip Name field. And, if you name the folders holding each P2 card appropriately, like Cow Shoot-date-1, 2…, that will appear as Reel info in L&T.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
