Activity › Forums › Panasonic Cameras › P2 clip ingest difficulties
  • P2 clip ingest difficulties
    Posted by Grant Peacock on June 17, 2012 at 1:37 pm
    I have a multi-cam shoot that was put through a switcher and fed via HD-SDI to my HPG-20. The HPG-20 plays the switched feed, 10 min clip recording fine (A, V both good) but I am getting a red exclamation mark and ‘Error : Unknown’ in the Status column of Final Cut Pro 7.0.3 Log and Transfer.
    I also note that the thumbnail in the FCP Log and Transfer window has a strong green cast on screen, compared to that seen on playback in the HPG-20.
    What could I be missing here? I haven’t found anything online that helps with this issue. P2CMS is all up to date, as is Final Cut Pro. Cameras were set to 720p60. The HPG-20 was set to record AVC Intra 100.
    Grant.
    Grant Peacock replied 14 years, 3 months ago 3 Members · 5 Replies
  • Chris Tompkins
    June 17, 2012 at 3:49 pm
    Did you off-load ALL the P2 Cards to the computer first?
    Did you verify-copy like with software “ShotPutPro” or “P2CMS” ?
    You may have a clip that is spanned cards…
    Chris Tompkins
    Video Atlanta LLC
  • Grant Peacock
    June 18, 2012 at 12:33 am
    Thanks Chris.
    You are right – I AM seeing the spanned clips effect. After repeated efforts at ingesting, I’m now getting file versions with appended file names.
    Is it best, in a case like this, to perhaps purge everything off the drive and attempt to ingest again?
    Your approach – focusing on the spanned clips issue, would perhaps also explain the ‘?’ status in the thumbnail view in the camera, which I also tried using as a playback/transfer device (but being an HPX-500, I also figured it may be precluded from playing back anything in AVC-Intra).
    Grant.
  • Chris Tompkins
    June 18, 2012 at 10:54 am
    Sounds like you’re doubling up a bit on the files.
    I would suspect some issues with the 500 and AVCiNTRA files as well.
    Is this what you are using as a card reader then?
    You might have a damaged clip w/ a “?”
    If it is getting messy, then remove all and start over sure.
    Chris Tompkins
    Video Atlanta LLC
  • Steve Eisen
    June 18, 2012 at 9:45 pm
    [Grant Peacock] “Your approach – focusing on the spanned clips issue, would perhaps also explain the ‘?’ status in the thumbnail view in the camera, which I also tried using as a playback/transfer device (but being an HPX-500, I also figured it may be precluded from playing back anything in AVC-Intra).”
    The HPX-500 does not playback AVC-Intra. You will need the HPG-20, HPX370 or HPX250. Any P2 card reader will also work.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Grant Peacock
    June 19, 2012 at 1:05 pm
    Steve and Chris,
    Thanks both. The primary device here is the HPG-20 (which was also used to record this clip). Later, I simply tried the HPX-500 as an alternative, not really expecting that it could work with AVC Intra (and probably proved that it doesn’t).
    I feel that there is something I am missing in regard to the spanned clips issue, but nothing I have found online nor in manuals is helping. P2 is not easy to work with in situations like this (elusive solutions).
    Thanks again for your input.
    Grant.
