Activity Forums Panasonic Cameras P2 Clip Import Problem
  • P2 Clip Import Problem
    Posted by Aaron Wells on November 18, 2006 at 11:34 pm
    I have a clip on an 8GB P2 card. It previews fine (audio and video) prior to importing into FCP; the entire clip plays. However… after import the imported clip plays a few frames of video and then goes blank. Tried importing several times on different computers with identical results. Clips shot prior to and after this clip import fine. I noticed that when importing the clip show that it is “spanned”… but it’s not; only this 8GB P2 card was in the camera when it was shot. I tried to repair the clip via the camera, but a message comes up telling me the clip cannot be repaired.
    Any ideas…? Thanks!
    Aaron
    Gerret Warner replied 19 years, 9 months ago 5 Members · 12 Replies
  • 12 Replies
  • Izoneguy
    November 19, 2006 at 6:18 pm
    How large is the file??
    Is it over 4 gigs???
    Try this:
    Copy the P2 contents to the hard drive…
    make a new folder copy CONTENTS and LASTCLIP.txt
    and then try importing from that….
  • Aaron Wells
    November 19, 2006 at 6:39 pm
    Yes, over 4 gigs. We finally imported by playing back from the camera & digitizing via firewire. I’d still like to know what happened and why… and more importantly, how to prevent in the future. Regardless, I’ll give your suggestion a shot. Thanks!
  • Izoneguy
    November 20, 2006 at 2:21 am
    What kind of drive where you trying to copy to?
    MAC formatted should have no problem over 4 gig?
    Is it FAT 32 formatted drives that will have
    problems over 4 gigs??
  • Aaron Wells
    November 20, 2006 at 3:09 am
    Mac formatted.
  • Izoneguy
    November 20, 2006 at 3:35 pm
    I think the P2 cards themselves are FAT32….
    so the reason it said spanned clip is that
    the 8 gig card records upto 4 gig and then
    would span the clip I guess??
  • Shane Ross
    November 20, 2006 at 3:49 pm
    [izoneguy] “I think the P2 cards themselves are FAT32….”
    They aren’t hard drives, so they aren’t formatted with a hard drive format.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Izoneguy
    November 20, 2006 at 4:32 pm
    Shane,
    Direct from a Panasonic .pdf on how to work with P2.
    https://broadcast.panasonic-solutions.ru/Catalog/P2/Final_Cut_Pro_5_AG-HVX200E.pdf
    Page 6 near the bottom of the page.
    [PDF] Late-Breaking News About Final Cut Pro 5File Format: PDF/Adobe Acrobat – View as HTML
    You can use a Panasonic memory card reader or a P2 Store drive to import or copy … Note: P2 files use the FAT32 format and are therefore limited to 4 GB. …
    broadcast.panasonic-solutions.ru/Catalog/P2/Final_Cut_Pro_5_AG-HVX200E.pdf – Similar pages
    5 When you have finished, eject (unmount) the P2 card before disconnecting the USB device, or before removing the card.
  • Shane Ross
    November 20, 2006 at 5:08 pm
    Well lookee there.
    Hush my mouth. And I am a leader too. Embarassing.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Gerret Warner
    November 20, 2006 at 5:45 pm
    I’m confused…and concerned now that I’ve shot a bunch of 8-gig cards. I copied many of them via the card slot on my G4 laptop and others I copied from our P2 Store.
    I’m about to import them into FCP and this thread makes it sound as if I may have trouble with the import. I’ve tested several cards before and didn’t have any problems.
    Should I be concerned?
  • Izoneguy
    November 20, 2006 at 9:40 pm
    Good question….
    It sounds like the 8 gig cards will
    span two 4 gig clips together if
    you record for lets say in 720 24pN more than 10
    minutes on one shot….
    This should be no different than recording
    with 2 – 4 gig cards….
    With FCP 5.1.2 the process of joining 2 spanned clips
    seems to work much better than in the past…
    Just test until you get your system down…
