Activity Forums Apple Final Cut Pro Legacy P2 cards not recgnised by FCP6, despite Finder recognising them
  • P2 cards not recgnised by FCP6, despite Finder recognising them
    Posted by Sam Davies on September 23, 2008 at 12:23 pm
    Hi all,
    So, I have a bunch of 720p 25pn footage. Two 16GB P2 cards, in an HVX200. Said camera is connected to an Intel dual core 2.8ghz iMac w/4GB RAM, running OSX 10.4.11
    The two P2 cards are showing up in Finder as ‘No Name’ drives, as per usual.
    I open up FCP 6.0.4, create a new project, and save. Then I open the ‘log and transfer’ window.
    Here’s where things get weird.
    It used to be that all of the footage would appear automatically, I’d name it etc. and then transfer it all.
    But today for some reason it’s not recognising the cards. So I manually select the cards, and still FCP won’t show me the footage. I copied the cards across into folders on an external HDD and tried to select those, but no luck either.
    I know the footage is fine because I’ve watched it on the camera, as well as using P2CMS.
    I clicked the preferences tab thing and looked, and I noticed that there was no mention of DVCPro HD codecs, just AVC-Intra and AVCHD being transfered to Apple ProRes 422. Could this be the problem?
    Any help would be greatly appreciated.
    Matt Larson replied 17 years, 11 months ago 4 Members · 5 Replies
  • Shane Ross
    September 23, 2008 at 2:10 pm
    DO you have FXFactory installed? Demo or full version? That intereferes with P2 import. Either remove it (uninstall) or update it to version 2.0.1.
    Shane
  • Jeremy Garchow
    September 23, 2008 at 4:32 pm
    …what Shane says, and copy the footage off of the cards on to your hard drive before doing the log and transfer.
    Jeremy
  • Sam Davies
    September 23, 2008 at 9:09 pm
    Thanks guys, I do, and as soon as I find the ‘uninstall button’ it’s gone.
    Cheers
  • Sam Davies
    September 23, 2008 at 9:21 pm
    Anyone know how to get rid of the bloody app? I’ve looked through help files and can’t see anything about unistalling, so I used AppZapper, restarted, and still FCP won’t pickup the cards….
    What did I miss?
  • Matt Larson
    September 23, 2008 at 9:25 pm
    Open up the actual Application for FX Factory and under the “Action” menu it looks like there is an “Uninstall…” option
