Activity Forums Panasonic Cameras P2 Card Questions
  • P2 Card Questions
    Posted by Rick Pearl on August 2, 2007 at 7:54 pm
    What if anything, can cause damage to a P2 card? Magnets, extreme heat or cold, etc?
    Once a video is imported from a P2 card and encoded on some format, is metadata about the camera that it was recorded on still somehow retrievable? We ae going to be using multiple HVXs and am just curious if it will track this info by serial # or some other identifier?
    Barry Green replied 19 years, 1 month ago 2 Members · 1 Reply
  • Barry Green
    August 2, 2007 at 10:47 pm
    [quote]
    What if anything, can cause damage to a P2 card? Magnets, extreme heat or cold, etc?[/quote]
    A sledgehammer might do it.
    Short of that, nothing I’ve been able to throw at it. I’ve had ’em in 115-degree 90% humidity, I’ve used ’em in the arctic, I’ve had ’em in the desert. They’re heat-proof, dust-proof, humidity-proof, shock-proof, g-force-proof, snow-proof, and probably waterproof too. I’ve dropped ’em on the ground and dragged ’em across the carpet trying to cause static electricity; no effect. I’ve rubbed ’em on CRT monitors, put ’em near loudspeakers, put ’em near magnets… nothing affects ’em. I’ve seen footage of them used at the South Pole, I know we had 150 of them up in the Arctic for 1100 miles from Anchorage to Nome, and I’ve seen ’em be used in Death Valley. I’ve talked to shooters from NDTV who’ve shot with ’em during monsoons in India.
    [rick.pearl] “Once a video is imported from a P2 card and encoded on some format, is metadata about the camera that it was recorded on still somehow retrievable? We ae going to be using multiple HVXs and am just curious if it will track this info by serial # or some other identifier?”
    The metadata records the serial number of the camera that recorded the clip, yes. The name of the manufacturer, the exact model number, and the serial number, are all embedded in the metadata. As long as you keep your original MXF files directly from the card, you’ll always have that metadata available to you.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
