Activity Forums Panasonic Cameras p2 card offload
  • p2 card offload
    Posted by Joel Guy on March 16, 2010 at 7:16 am
    My p2 is not connecting to my mac book pro when I go to do the usual card offload. My p2 has been taking a beating over the last year, but has always been good to me, and registered when I try connect to my mac.
    I have tried a new fire wire cable, gone to a hard drive, gone straight to mac… My 5 cards a full and I was looking for another way to offload these cards? Card readers? another way out of camera?
    Mahalo, Joel
    Jeremy Garchow replied 16 years, 4 months ago 7 Members · 15 Replies
  • 15 Replies
  • Noah Kadner
    March 16, 2010 at 4:55 pm
    Could be a blown or nearly blown port either on camera or computer. Try on another computer.
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
    Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
  • Joel Guy
    March 16, 2010 at 5:41 pm
    Thanks Noah. I believe it is the port on camera, as mac is bran new and it reads a multiple of hard drives on port. Is there another way to get info from cards to computer?
  • Noah Kadner
    March 16, 2010 at 7:00 pm
    Sure- read through this forum and you’ll find several alternatives…
    Noah
  • Matthew Sonnenfeld
    March 16, 2010 at 10:30 pm
    Assuming that you’re on snow leopard (based on this being a new mac), there really is not a quick and simple way to offload your P2 footage. The duel adapter used to be the best but now with snow leopard that won’t work. And regardless, the only MBP with an expresscard port now is the 17″ (… thanks apple…).
    So here are your alternatives. On the high end of the budget you could get a Panasonic 5 slot card reader that will read through firewire or USB but that will run about two thousand dollars as I’m sure you know.
    There are two midrange alternatives that you can consider. If you DO have the 17″ MBP and have the expresscard 34 slot, you can get the Sonnett QIO. This will run you a thousand dollars. The other choice would be to purchase a PC laptop with an PCMCIA slot and just offload to an external hard drive through a PC and P2 software. You can get a cheap laptop nowadays anywhere and you don’t need anything with any sort of power to it… just the card slot.
    The cheapest thing to do you unfortunately can’t do now. In April, Panasonic will FINALLY be releasing a single slot, dual USB cable P2 card reader that will work on snow leopard. Based on what I’m hearing from you though, you don’t have time to wait until then and I completely understand and sympathize. I think that the nonsense that has gone on with P2 over the last few months is completely unwarranted.
    Hope you figure it out!
    Best,
    Matt
    Panasonic HPX170 P
    2008 Unibody Macbook Pro 15 inch, 2.8 Ghz, 4GB RAM
    CalDigit VR
    Final Cut Pro Studio 3
    Avid Media Composer
    The College of WIlliam and Mary
  • Jeremy Garchow
    March 17, 2010 at 1:20 am
    You are going to have to spend money to transfer p2 cards. If people spent money (now you can spend under $1000) you
    complain less about the format and get to work. P2 works extremely well, you just need the right tools to do it. Sorry, I’m a little tired of people blaming p2 “nonsense” who are simply too scared to spend another grand or two on something that actually works and was designed by Panasonic to employ p2.
    I have never really seen too many complaints about a pcd20 or pcd35 on these forums. No news is good news in that respect. I’m sure the one slot reader will work as well, but if you’re going to plop down some money, you might as well get a reader that does more than one card at a time. I have high hopes for the QIO but haven’t seen it in action.
    For the original poster, you can also try and find a used p2 store on eBay. It can act as a USB card reader that uses the same batteries as the 170/200. It can download 60GBs of material to the unit as well.
  • Noah Kadner
    March 17, 2010 at 6:02 am
    Yeah those PCD readers just work- but they are pricey… Duel Adapter is junk but it’s cheap junk. Fast-cheap-good- pick two.
    Noah
  • Joel Guy
    March 17, 2010 at 8:26 am
    “you can also try and find a used p2 store on eBay” what is a p2 store? Could I get an older powerbook with a card reader on it and use that? or is the pc a better way to go until the single card reader is out.
    thanks, joel
  • Steve Eisen
    March 17, 2010 at 1:31 pm
    Google P2 Store and see what comes up.
    Yes you can use a Powerbook with a PCMCIA slot to offload.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jeremy Garchow
    The p2 store is a one slot reader that also has a 60 gig hard drive in it. It’s a little long in the tooth due to the small hard drive, but works just fine as a card reader.
    https://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?displayTab=O&storeId=11201&catalogId=13051&itemId=94262&catGroupId=34402&surfModel=AJ-PCS060G
  • Paul Hudson
    March 17, 2010 at 2:28 pm
    I have an older Mac Book with a slot that I keep around to download with.It works great. I also have a Duel Adapter for my MacBook Pro and have never had an issue with it. I guess I must be the lucky one.
    Paul Hudson
    Lizardlandvideo.com
    Phoenix Video Production
