Activity › Forums › Panasonic Cameras › P2-Card driver problem with Lenovo W500
  • P2-Card driver problem with Lenovo W500
    Posted by Sandro Cannova on July 6, 2010 at 7:13 am
    Hi there,
    I usually don’t work with the P2-Card, hence I’m not overly experienced with it. However I received a few from a production to import into Avid using a Lenovo W500 and its PCMCIA slot.
    The problem is that the Panasonic P2 drivers wouldn’t work with the notebook, so the card wouldn’t be at all recognised by the machine. I downloaded the 64-bit (Vista) version and during the installation process I am asked to insert a card in the card slot, so the setup-application is able to recognise it. Well this wouldn’t work. Does anyone have a solution for me or did anyone experience the same problem I do?
    Thank you and good-bye,
    Sandro
    Sandro Cannova replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
