Activity Forums Panasonic Cameras P2 / BM Intensity / Data Rate
  • P2 / BM Intensity / Data Rate
    Posted by Michael Lyas on May 26, 2010 at 2:53 am
    Hi
    I have to preface this post by saying I think I have made a cardinal sin in forum terms by admitting I have posted this same post on another forum, but without response, so I’ll try here if you all don’t mind.
    I recently bought a Panasonic AG-HPX302en (Australia) running FCP 7.0.2
    Setting cam to AVC Intra 100 25p
    In Audio/Settings I choose the following:
    Sequence Preset: Apple ProRes 422 (HQ) 1920 x 1080 25p 48KHz
    Capture Preset: Blackmagic HDTV 1080i uncompressed
    After I’ve ingested footage into FCP, the browser is showing that the clip’s Data Rate is 13.9 MB/sec
    Is this a bit low?
    If anyone uses the Intensity card, is there another Capture Preset I should be using or is this FCP’s way using ProRes to reduce / compress the footage.
    In FCP the drop down window for the Capture Preset doesn’t really give me a lot of options, I think the HDTV 1080i 50 is about the best option, but I’m sure that’s dropping the data rate.
    The BM card is only 8 bit I know, but it’s not like I’m using the BM to capture the footage, I use it only to monitor with a 32″ Panny LCD TV
    That said, I have captured 8 bit uncompressed video via HDMI and a Canon HF 10 and that shows up at a data rate of 99 – 101 MB/sec
    Any ideas would be welcome, thanks
    Michael
    Jeremy Garchow replied 16 years, 3 months ago 4 Members · 3 Replies
  • Grant Gomm
    May 26, 2010 at 7:11 pm
    I don’t think 13MB per second is bad actually… now that being said, 13Mb per second would be horrible!
  • Matthew Romanis
    May 26, 2010 at 10:37 pm
    Let’s not get bits and bytes mixed up.
    13MBps is roughly 100mbps, so what’s bad about that again?
  • Jeremy Garchow
    May 28, 2010 at 1:39 pm
    Are you caturing or log and transfer?
    If log and transfer, what you areseeingbis fine as AVC-Intra 100 is 100mbps, or around 14MBytes per second as has been mentioned.
