Activity › Forums › Panasonic Cameras › P2 backup when I shoot
Posted by Alaa Ghuniem on October 20, 2008 at 8:37 amdear …
I need solution to make backup copy from the P2 while I ‘m shooting like fire wire HDD , so the camera store in the same time on fire wire HDD and on the P2
thank youRichard Herd replied 17 years, 11 months ago 5 Members · 7 Replies -
Steve Eisen
October 20, 2008 at 12:13 pmFocus Enhancements Firestore FS-100.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Alaa Ghuniem
October 20, 2008 at 1:29 pmbut it is not in the same time I must change my Camera to make host 1394
Shane Ross
October 20, 2008 at 2:21 pmCan’t be done. Either P2 or Focus. You cannot send a signal out to a bare firewire drive. You MIGHT be able to send a signal to a computer running FCP, then to a firewire drive. But that won’t garner the same time code as is on the P2 cards, and you are tethered to a computer and drive.
Might…I haven’t tried it. Why do you want to do this? P2 is pretty hardy. Only data loss has been due to human error.
Shane
Read my blog, Little Frog in High Def -
Alaa Ghuniem
October 20, 2008 at 2:30 pmthank you for your response
the director I work with it is first time to use the P2 so he is so worry to loose any shoot so he need somthing to be sure all the files will not loose , so what you suggest to let him be sure all the data will be in safe
not like one from this forum lost every thing
do you have safe workflow from P2 to PC do you suggest to me the best thing I can do to keep all file in safe place
Alaa -
Shane Ross
October 20, 2008 at 3:37 pmGet SHOTPUT P2 (www.imagineproducts.com). It will copy the files off the card, verify the copy, and make sure that EVERYTHING is copied.
Shane
John Fishback
October 20, 2008 at 4:09 pmAnd while it copies the files off each P2 card, then it can make simultaneous copies to up to 3 destination drives.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Richard Herd
October 20, 2008 at 4:56 pmIdeally, you can have someone available on set to copy and verify the footage. This will add an additional person to the shoot.
