Activity Forums Apple Final Cut Pro Legacy P2 AVCIntra import into Final Cut Pro
  • P2 AVCIntra import into Final Cut Pro
    Posted by Simon Morgan on October 3, 2007 at 2:34 pm
    Just wondering about shooting in AVCIntra codec on HPX2000 and then bringing into FCP. what are my options for codecs? Also, anyway to create smaller file sizes from P2 cards to edit for a long form doc series… I will have hundreds of hours of footage shot on P2 and want to be able to do an HD offline (with DV size file sizes) and then HD online… want some way to save space for offline and then recapture/relink to hi res files for online.
    John Heagy replied 18 years, 11 months ago 5 Members · 5 Replies
  • Eric Peterson
    October 3, 2007 at 5:55 pm
    You can transcode the files to any codec you want through Compressor. I don’t know much about AVC intra, but shooting 720/24 with the HVX200 file sizes were only 1.5 time bigger than standard DV files. I don’t think that is a bad trade off for working in HD.
  • Simon Morgan
    October 3, 2007 at 6:32 pm
    yeah, usually I work in 720pN with P2 cards, but I have to shoot either 1080p DVCPROHD or in AVCIntra100. Looking for a way to save space in post… if I have 100 hours of 1080p shot at AVCIntra100 and bring it in to FCP at Pro res 422 I will need 8 TB to store that footage. If I shoot it at 1080 DVCPRO HD I will need just over 6TB to store it. I will more than likely have 200 hours or more of footage for a full season of a show (and may need access to all footage all of the time) so I need some way to be able to offline at a lower codec. I think compressor will just take way too long.
  • Glaremedia
    October 4, 2007 at 10:01 pm
    With file based footage the offline online workflow is tricky as you will have todo a conversion from high quality to low quality which takes time.
    200hrs shooting on P2 would also be a challenge i would have thought.
    That footage will need to be on a big raid and probably backed up to firewire drives anyway
    My feeling is your shooting with the wrong camera !
    You would be better off shooting either DVC PRO 100 tape
    HDCAM tape
    or maybe XDCAM HD
    Good luck, you will need it.
  • Mj Schirmer
    October 6, 2007 at 8:28 pm
    Is there a clearly documented post flow for AVC-100 through FCP 2 (6.0.1)?
    I am ACing a feature starting next week on the HPX -3000 P2. It seems like there might soon be an FCP update for AVC HD native support… but till then, what do we do?
    I cannot see the AVC files in our tests on Log and Capture- is there another way to open
    and transcode?
    Right now we’re leaning toward shooting in DVCPRO HD codec, 59.94i @ 24PA,
    1280×1080. This is a bummer since we have a camera that can capture true 1080p
    on AVC and work with the material.
    Any thoughts?
    – MJ
  • John Heagy
    October 16, 2007 at 5:03 pm
    Don’t hold your breath for native support for AVCintra. The encoding proccess is way too computensive. That’s why ProRes is not H.264 based. Most hardware H.264 encoders have a 1 to 2 sec latency so software encoding is years away. Pile on the need to maintain realtime effects and it pushes it back even further.
