Activity Forums Avid Media Composer P2 and multiple frame rates
  • P2 and multiple frame rates
    Posted by Dan Ar on October 31, 2008 at 7:24 pm
    working on Media Composer 3.0 on a macbook pro laptop. With P2 footage, does avid allow you to work with footage shot at multiple frame rates? One card I tried to import had 3 clips at 23.98 and one clip at 59.94 – all footage is 720P. If I cannot work with both at the same time, what if any workarounds are available. Thanks.
    dan
    Elijah Wood replied 17 years, 6 months ago 5 Members · 5 Replies
  • Terence Curren
    November 1, 2008 at 5:33 am
    I won’t even mention that friends don’t let friends edit P2 in Avid. Oops, I just did….
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Shane Ross
    November 1, 2008 at 7:13 am
    Why not? The Avid P2 workflow is pretty slick. Multiple frame rates aside…that is a whole ‘nother can of worms. YOu need to convert one frame rate to match the other. With FCP I’d use Compressor…not sure what Avid allows. Transcode perhaps? Could run a few tests.
    Shane
  • Job Ter burg
    November 1, 2008 at 11:12 am
    RayLight MXFX will let you change frames rates (and other things) on P2 media, while retaining metadata.
  • Terence Curren
    November 1, 2008 at 10:51 pm
    Relinking issues with P2 in Avid.
    You can find stuff in the Avid Community Forums on their website in regards to these issues.
    Terence Curren
    Burbank,Ca
  • Elijah Wood
    November 3, 2008 at 4:54 am
    In an edit where 25p was being mixed with 50p in PAL land for a 25p project, I took the P2 media that was 50p and imported it into a Premiere CS3 project with settings of 25p. The Premiere project being at 25p would render the 50p P2 media into 25p video. I then used Adobe’s export P2 Media which created a virtual P2 card of the converted 50p to 25p media. I then imported that virtual P2 card back into the Avid which digested it happily.
    That’s one way to do it, if you’ve got a copy of Premiere CS3 or CS4 handy. I did try to find a way to do it on the Avid but didn’t have any luck. That was Media Composer 3.
    Elijah.
