Activity Forums Apple Final Cut Pro p2 and fcp x
  • p2 and fcp x
    Posted by James Carroccio on October 4, 2012 at 9:23 pm
    hello all,
    I use a panasonic hvx200 and have bought the new final cut.
    Most clips ingest fine, a select few do not.
    I go from Import from camera > open archive > select all the clips ( all clips play fine in here) > import > then I get a Import Failed box “the following clip encountered an error during import and is still referencing media on the camera: …. some clips import others get the import failed message
    furthermore, i can’t choose the share option at all.
    thank you
    James
    Camera Operator/Production Tech
    John Fishback replied 13 years, 10 months ago 2 Members · 1 Reply
  • John Fishback
    October 9, 2012 at 9:57 pm
    Does your camera have a Repair P2 capability? It’d be in the same menus you use when formatting P2 cards. Try that and see if it helps.
    John
    MacPro 8-core 2.8GHz, 8 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.5
    Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
