Activity › Forums › AJA Video Systems › P-22 vs SMPTE-C phosphors for color correction?
Posted by Jim Blokland on May 25, 2005 at 1:15 amAny difference between the two?
Best, JIM.
Jason Howard replied 21 years, 3 months ago 2 Members · 1 Reply -
1 Reply
Jason Howard
May 25, 2005 at 7:05 amHi Jim,
The quick answer is: Yes – there is a difference. My suggestion is you go with SMPTE-C as it is much closer to Rec.601 colorimetry specs being used by pretty much all colorspace calculations (with the exception of HD, that is).
The difference between the two has to do with the peak wavelength emission of each of the three primary color phosphors as well as the overall white point. See https://www.videoessentials.com/res_phosphors.php for several comparesons of phosphor gamuts.
Also, here is a list of the CIE coordinates and whitepoints for common phosphors types:
https://www.cs.ucf.edu/courses/cap5725/spring2003/Chromaticity.htmHope that helps answer your question.
JasonJason Howard
Linux & Media COW Leaderhttps://www.spectsoft.com
https://www.psinux.org
