Activity › Forums › Storage & Archiving › OWC USB 3.0 to Esata Adapter with RAID drives
  • OWC USB 3.0 to Esata Adapter with RAID drives
    Posted by Franklin Peterson on May 30, 2013 at 7:53 pm
    Hey all,
    I’m about to start an edit and am working with a newer iMac that doesn’t have esata or firewire 800 connections and I need to work with several RAID drives that don’t have thunderbolt support.
    I saw this adapter for usb 3.0 to eSata and wondered if anyone has worked with it or had any issues.
    https://eshop.macsales.com/item/Newer%20Technology/ADESATAUSB3/
    It almost seems too good to be true, but any advice would be appreciated as this needs to be super stable.
    -Franklin
    Rainer Wirth replied 13 years, 4 months ago 3 Members · 2 Replies
  • Alex Gerulaitis
    May 30, 2013 at 11:14 pm
    It should theoretically work.
    One issue to watch out for, is that some eSATA RAID boxes require port-replicated (aka port-multiplier) eSATA. If yours does, you’d want to ensure that device supports it.
  • Rainer Wirth
    May 31, 2013 at 11:37 am
    If you edit this way I wonder, whether you have got enough speed?
    One interesting solution is Sonnet echo, which gives you the choice of up to two PCIx Slots to thunderbolt. For Example one slot for a breakout video/audio signal and one for a esata or FC connection. The speed should be greater than with USB 3.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
