Activity Forums Apple Final Cut Pro Legacy Overwriting footage without loosing effects
  • Overwriting footage without loosing effects
    Posted by Chris Heuer on August 7, 2008 at 3:30 am
    I’m embarrassed to even ask this but it’s late and I’m frustrated.
    I just want to replace a shot at the opening of a sequence. There is a fade effect at the start of the clip and a dissolve to the next shot at the end. When I overwrite the new footage, the transitions go away.
    Is there any way to replace the footage without changing anything else in the sequence. I should just add the transitions back in and be done, but that wouldn’t be learning!
    Thanks, Chris
    Chris Heuer
    Freefall FX, LLC
    David Roth weiss replied 18 years ago 2 Members · 1 Reply
  • David Roth weiss
    August 7, 2008 at 3:36 am
    That’s call “Replace” and you’ll notice that it’s one of the options available when dragging a clip to cut in from the viewer to the canvas. If you can’t figure out how to use it properly check the oneline manual in the Help menu.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
