Activity › Forums › Avid Media Composer › Overwrite edit versus separate track
  • Overwrite edit versus separate track
    Posted by Dr Michael midgley on January 27, 2006 at 2:40 pm
    I use Avid Xpress Pro. I do a lot of talking to camera and then superimposing visuals over what I am describing in words. Up to now I have used ‘Overwrite Edit’ for this purpose. However, putting the visual on a separate dedicated track and then mixing down before doing a ‘Digital Cut’ seems to be another possibilty.
    I’m not sufficiently experienced to decide which is the better method in the long term.
    Can you help me by suggesting the advantages of one method over the other please, or at least some of them if it’s a long list!
    Thanks in anticipation – Michael
    Charley King replied 20 years, 8 months ago 4 Members · 6 Replies
  • Charley King
    January 27, 2006 at 4:31 pm
    If you don’t need a lot of tracks, this is a nice way of looking at a shot over the narration, inteview, or just natural sound. I do it a lot with no real purpose, other than it is easy to take out a shot by lift, overwrite, and the track under remains intact, it is also easy to do sample cuts back and forth and if the cuts don’t work, you haven’t actually done anything. No real purpose behiond this method, other than for me I found it convenient. I even sometimes work with three tracks and by moving the track view up and down I can see which track I prefer at any given moment. Hope this helps.
    Charlie
    ProductionKing Video Services
    Unmarked Door Productions
    Flamingo Las Vegas Hotel
    Las Vegas, Nevada
  • Alex Alexzander
    January 27, 2006 at 10:21 pm
    I do the same. I add tracks. Not uncommon for me to have 6 or 7 video tracks. It’s an easy way to go. But, if you master the various trim techniques, it’s darn good that way too.
    -Alex Alexzander
  • Dr Michael midgley
    January 28, 2006 at 9:14 am
    Charlie and Alex – thanks for your help – I understand the points you are making – much appreciated.
  • Mark Raudonis
    January 28, 2006 at 4:55 pm
    Stacking tracks rather than cutting on a single track is fine, but here’s where it can haunt you.
    If you’re consolidating media, or “up-rezzing” your sequence, having multiple “unused” layers will just mean that your redigitizing more material than you’ll ever use. This isn’t a bad thing… it just takes up more space and more time to accomplish. On the other hand, you will have more ability to change things in the on-line if that’s necessary.
    So, if you want to “create” this way, fine. I’d suggest that you collapse all tracks before you move to a higher resolution.
    Mark
    January 29, 2006 at 9:07 am
    Many thanks for your input – much appreciated – Michael
  • Charley King
    January 30, 2006 at 4:29 pm
    [Mark Raudonis] “I’d suggest that you collapse all tracks before you move to a higher resolution.”
    Exactly.
    Charlie
    Las Vegas, Nevada
