Activity Forums DVD Authoring Overscan lines and Encoding using Apple Compressor
  • Overscan lines and Encoding using Apple Compressor
    Posted by Nick on July 9, 2006 at 12:54 am
    My 35mm transferred to a 16:9 QT file has some noise running down the left side (maybe part of the audio track or something) — it only appears on the monitor, but not on the TV. Also, I’ve been reading on the net about “overscan lines” – apparently there’s one at the very bottom of the frame, which I’m supposed to crop before encoding.
    Should I somehow be cropping these areas (on the sides and the bottom) before encoding to increase the effectiveness of the encode? If I am, what do I keep in mind given I’m working with 16:9 video?
    I’m encoding using Apple’s Compressor — setting a bunch of compression markers in FCP to ensure the encode is effective — and I’m happy with the results so far. Just wanting to see if I working on dealing with the overscan areas will get me more efficiencies.
    Any ideas/thoughts on what to do about the overscan lines for encoding?
    Nikhil
    https://www.indiancowboy.com
    Noah Kadner replied 20 years, 2 months ago 2 Members · 1 Reply
  • Noah Kadner
    July 9, 2006 at 1:58 am
    I would not crop because you’ll be decreasing quality. But if you want to matte in a border on the sides to cover the area that would preserve the quality while covering up the junk just in case someone is watching on a computer rather than their computer.
    Noah
