Activity › Forums › Apple Final Cut Pro Legacy › Overriding media in/outs?
Posted by Peter Dewit on October 19, 2007 at 1:41 pmDoes anyone know if there’s a way to manually change the media in/out points in FCP 6? More specifically I want the audio and video media timecodes to match on some clips that the audio TC is different.
Peter Dewit replied 18 years, 11 months ago 3 Members · 4 Replies -
David Bogie
October 19, 2007 at 2:14 pm[Peterd] “Does anyone know if there’s a way to manually change the media in/out points in FCP 6? More specifically I want the audio and video media timecodes to match on some clips that the audio TC is different.
“Try to rephrase that one more time. I’m not watching over your shoulder.
Meantime, look in the manual for auxiliary timecode.
bogiesan
Peter Dewit
October 19, 2007 at 2:32 pmOk allow me to explain a little further. I used automatic duck for some media files. There is apparently a bug in FCP that is making Final Cut not correctly interpret the timecode in aiff files.
I’m ending up with clips that have the correct media ins and outs for the video but audio media always starts at zero.
John Pale
October 19, 2007 at 4:20 pm[Peterd] “I’m ending up with clips that have the correct media ins and outs for the video but audio media always starts at zero. “
Give your AIFF files a reel number and they will be treated like tape sources, and the timecode will be preserved.
You can also do what you are suggesting by loading it into the viewer and using the Modify/Timecode command.
Peter Dewit
October 19, 2007 at 4:48 pmWell Automatic duck handles the copying and linking of the aiff files so directly manipulating them would be tough. However I think the modify timecode option should work. I’ll have to test it out.
