Activity Forums Adobe After Effects overriding all the strokes in a project
  • overriding all the strokes in a project
    Posted by Sara Haralson on June 6, 2019 at 3:44 pm
    Is there a way to override all the strokes in a project? A client of mine just decided they want thicker strokes on all shape layers in the 11th hour. Any help is greatly appreciated!!
    Tomas Bumbulevičius replied 7 years, 2 months ago 3 Members · 2 Replies
  • Sergio Cabrera
    June 7, 2019 at 1:16 am
    You can make a script with an array of layers, then apply a condition, if stroke = X, then apply the stroke you want to all of them.
  • Tomas Bumbulevičius
    June 7, 2019 at 7:01 am
    Sara – it depends, whether you have grouped shapes inside the layers, which has stroke & not at all in the same layer.
    If such condition is true, then looking for a scripting solution will be the fastest approach, in case if there are many layers.
    Alternatively, in case if all shapes has strokes, you can select all ‘Shapes label’/comp, and change all in the comp instantly. This only applies if you haven’t changed label colors for different shape layers, during the process.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
